Well my new blue 2004 toy has it own set of problems which of course end up being emissions related.
Regen works but assist doesnt. The only codes are the ones above. The P2A00 seems rare but if you look at this picture it appears someone wired in the O2 sensor directly. I am not sure sure what cable goes where to confirm if they did it right or possibly have the wrong O2 sensor which seems common also....
I have ground cables and a 3rd gridcharger cable on order. I am not sure if I should go right after the O2 sensor or replace ground cables, do some fuel cleaner and grid charge it first.....
Thoughts? Feelings? Suggestions?
BUMP any quick way to confirm they wired this right?
Are the wires at each end of the splices the same color? This is probably a repair of rodent damage.
Four wires VS five?
Wrong sensor?
Four wires VS five?
Wrong sensor?
It's 4 wires and colors don't really match since they are different on either side...should there be 5 on a 2004 MT?
