Hi Guys,
Need to get some more battery capacity into the rally car.I believe a second standard Insight or Civic pack has been fitted in parallel by some members of the community and i would be grateful for any links to information on doing this.
Will post our progress on this and our motorsport activities in 2009.
cheers,
Paul
You can start with this thread:
viewtopic.php?f=4&t=7463
If interested in charging you can look at this thread:
viewtopic.php?f=4&t=3996
I also put the PTC strips of the second pack in series with the first as a thermal safety along with a potentiometer. The system is set to trip at ~130 F. The Pot controls this trigger point, but as worst case it will trip at a lower temp than stock. I also connected two of the battery temp probes to the civic pack. Theoretically this could be done with as many packs as you want. I have considered building a tri parallel pack built from Prius subpacks as they would take up less room.
Not at all, just keep in mind this probably the simplest approach while maintaining stock safeties.
About this Discussion
2 Participants
uhtrinity
Honda Insight Forum
Full Forum Listing
