Tonight I noticed an unusual thing that happened to my Scanguage II. I turned on the car and the SGII was dead, as in no data or backlight. This has never happened to me before. Screen has always light up upon turning the engine, showing data from last shut-off for a few seconds before "refreshing" the screen to show current data.
I thought for a few seconds...made sure the cable connection was secure on the back of the SGII, and it was. Then I decided to press the HOME button. The SGII came on, showing data from last shut-off briefly before showing current data. All good.
But should I be concerned? I consulted the manual when I got home, and a possible culprit is a blown (car) fuse, but if that were the case, then wouldn't the SGII not power up at all after pressing the HOME button? I checked to see if the SGII reset my settings, but it looks like my settings were not changed to factory default.
Is this a sypmtom of the SGII crapping out, or something with the Insight's computer/power source? Has this happened to anyone before?
On a side note, it seems to be a common thing to have the SGII's mpg reading not match up with the Insight's FCD readings--or at least there seems to be a delay from the SGII.
