Lockdown has given us a chance to do some long overdue work on our Insight. We were very lucky as about a week before the lockdown the IMA pack finally said 'no more!'. It had been complaining about low capacity for a couple of months...
Anyway, today we had first IMA start and brief drive on our BimSight lithium ion conversion project so I am rather happy. I have been working on this with another forum member who has an equally dead IMA pack.
You will have to excuse the very sketchy install as this was a proof of concept/initial test fit so it is all coming out again and getting a custom made bracket to hold everything in place. And yes, those are 2 magazines shoved in there as temporary insulation.
After an aborted plan to use some second hand but lightly used (and as it turns out uterly dead) 15Ah pouch cells I saw the BMW PHEV modules on the open inverter forum. It turns out they are a very nice fit in the Insight case! And someone had reverse engineered the CAN protocol!!
We bought a 2018 vintage 530e pack from a front end smashed car which yielded 6 modules each with 16 26Ah Samsung SDI cells. On the end of each module is a CAN connected supervisor which measures cell voltages and temps. It even has balancing build into the supervisor.
The stock BCM has been replaced with a custom board running a Teensy 3.6 module and a LEM 200A current sensor. The Teensy intercepts the METSCI (and can re-write the dash output) and generates a BATSCI to keep the MCM happy.
The test drive was all of 50ft as nothing is secure and the car is missing its front seats as part of a very long overdue deep clean. But it did show 4 bars of assist under the very brief acceleration. And no dash lights or codes showing on the OBD2C&C.
Next job is to weld up a support frame for the modules and the fuse/contactor assembly as well as get the seats back in ready for a longer drive. Still a lot of coding to do to get it to measure SOC and ensure it goes into low power mode when not running so it doesn't flatten the 12v battery
Not sure on cooling at the moment. In the BMW the modules are liquid cooled BUT the motor is 83kW! So hopefully in the Insight it will just need some forced air blowing over them.
