1 - 8 of 8 Posts
here's what works for me...
i put on a Fumoto drain valve with a one foot hose that extends a couple of inches past the aft aero fairing. I can slip a small plastic container under the hose from behind the right front wheel and open the drain valve by reaching over the top of the engine.
For the oil filter I can reach into the engine compartment at the left front and grab the filter by reaching across the front of the engine behind the radiator. This is possible because I flipped the intake elbow over to draw in combustion air from the area around the cat converter. I just put a small plastic container under the filter/adapter and twist the filter off enough to let it drain into the container. When it is finished draining i put a very small amount of silicone grease on the seal of a new filter, clean off the filter adapter, and spin the new one on as tight as I can without tools. I put a cover on the container so i can remove it without spilling any oil.
After the filter is changed I close the drain valve and put in 2.5 quarts of Mobil-1 0W20.
All done! No drips, no muss, no fuss.
Oil pump thing
I got one of the Pella (I think that is the brand) suction pumps, and I use that to pull out the bulk of the oil. Then by the time I open up the plug, there is hardly any left and I have never had a problem with having is slop all over me under the car!
FYI: I made some ramps as per a Ford Mustang site guy who posted photos of a series of stepped ramps he made using 2x6s stacked kind of like steps. Very easy to use, and no trouble running off by accident as I use 2 per side.
i figure it would be kinda tough to break the drain valve off. the aero fairings should protect it from small stuff, and if i run over something big enough to get through the fairings and get up around the back of the oil pan, i think i will have other problems to worry about first!
we shall see.......
Believe it or not, it's not that hard to get road debri up there to break things. That is one reason why manufactures will never use an oil valve over a bolt in that area. A cardboard box being hit at speed can be enough to break off or damage it enough to cause a leak.
Hi HafNHaf,
This sounds very interesting to me. I've just installed a Fumoto valve with a nipple so that I can also run a hose out for the oil drains. But unless I find a way to reach the filter from the top like you have, I will still need to remove the underbody panels to get to the filter. But I don't fully understand what and where you have moved things in order to reach the filter from the top. Any chance I could talk you into taking a few photos of your setup?
Thanks,
Bryan
Discussion Starter · #7 ·
i will try to take a few shots in the morning for you. hoping to get a chance to clean the insight up a bit tomorrow. supposed to hit 95 degrees by the afternoon. yuck! have to run the a/c on the way to work.
just read your thread about the fumoto valve install. very glad you were able to salvage that oil pan from the wrench-wielding gorilla! nice job... did your valve end up with the handle on the bottom? mine did, but i can still reach it from the top.
Awesome. I'd really appreciate that.
Fortunately, my ended up with the valve on the top.
Cheers, Bryan
1 - 8 of 8 Posts
