Unless the engine has been run with straight H2o there is no reason to pull the engine block plug and drain the coolant. It was mandatory with cast iron blocks but not required on aluminum blocks. Just draining the radiator and refilling with a 50-50 mix of collant will be sufficent. After removing the drain plug, let it set for a while and most of the fluid in the block will drain out. (IMPORTANT) Don't forget to "burp" the cooling system after filling. (There is an actual "burp" fitting.)
If you must:
The block plug is located on the reward side of the engine, behind the cat. converter and just above the oil pan fitting junction.
A 1/2 inch ratchet will remove the plug.
If you must:
