I recently added XM radio. I also bought an auxiliary connector from PIE called HON-AUX. It plugs into the radio's CD connector and converts it to RCA inputs you can use for any device, such as the XM radio.
I like the idea because it should let me select the CD button on the radio to switch to XM instead of using a cassette adapter or FM modulation.
Unfortunately, nothing happens when I select the CD. It's supposed to display CD 1 TRK 1 when the aux device is selected.
PIE claims the device to work with 1992-2002 Hondas. (Except Passport) PIE support is stumped. They've replaced the connector and even asked me to send them the radio the work out the issue.
Has anyone ever used the HON-AUX connector in this car or have any ideas about what the problem might be? Are there any issues with using the CD connector in this way?
Thanks.
Mark Glemboski
Thanks.
Mark Glemboski
