Friday I was surprised to find that my radio had turned itself on while I was away. This happened twice! OK, now I'm asking myself; is the radio covered by the warranty? Then I notice the time on the radio clock. That's funny there is no key in the ignition. :idea: I pull out the small solar panel that I have plugged into the 12 volt outlet near the shifter. The clock goes off. :roll:
Lesson 1.
Don't plug a solar charger into the 12 volt outlet because when the car is turned off the solar panel will not charge the battery.
Lesson 2.
If you ignore lesson 1, expect to find either a dead 12 volt battery or your Insight singing its heart out when the sun shines!
Lesson 1.
Lesson 2.
