Apparently I was not awake when I read the original post and apologize. The OP wrote that the pack was completely disconnected from the car, so there is no electrical connection between it and the PDU capacitors I spoke of. I think that as long as he did not start the car (IMA motor turning) and enough time had passed that they would remain discharged. Suggesting to consult the manual regarding safety still stands.As Sean mentioned, if the IMA wire harness is still plugged in, then when you turn the key on the IMA system could become energized...
