1 - 19 of 19 Posts
Anybody else annoyed by the dinky area cleared by the wiper on the rear window.window?
I increased mine by exchanging the flex arm and substituting 22" wiper blade.
The fixed connection that rotates with the wiper motor is as far as I know unique so I ground off the pin and substituted an extended flex arm so I could attach a 22" wiper blade clearing top and bottom.
If anyone else is interested i'll post details. Thanks to junk parts almost no cost unless you go for new wiper blade.
Finally, I can see out the rear !
Yep, I always like to fit the largest blade I can on the factory wiper arm. On my last car, that meant +2" on both the front blades.
However, I find Rain-X sufficient for the Insight's rear glass.
The stock 16" blade cannot be extended on mine unless I cut off the lower end where the latching is done. A longer arm from the lower section to the wiper hinge is required.
Never thought of that. I just removed mines and plugged the whole. In addition to use rainx, I go for shorter wiper blades.
Where'd you get the plug? I'm still using the wiper motor to plug my hole, but that's a needlessly ugly and heavy plug.
I'm hoping to find/make a piece of black plastic just the right size, and stick it in place with some flowable silicone sealant.
I got a plug from the hardware section of lowes. This is the isle with all the draws. I then got some black paint and silicone sealer.
I grabbed my rear wiper arm out of the pile of parts I've removed from the Insight and measured it. I had a 24" Bosch Micro Edge blade on the stock wiper arm. I guess some brands of blade fit better than others.
Cobb, thanks for the tip. I'll remove the wiper motor and add a Hillman plug this weekend.
Discussion Starter · #8 ·
Interesting. Wouldn't fit on mine hung up on the bottom.
PS Wiper suppliers all list the rear Insight wiper blade at 16". Thats why I exchanged the arm linkage.
I looked all over to find that specific Bosch Micro Edge 24", I looked at pretty much every auto shop I could think of and ended up finding one at Auto Zone for about $12 which is much more than I usually pay when I buy wiper assemblies. It seems to fit mine just fine. I hated the look of the Bosch blades when I had a Grand Am but I think this one looks better than the stock one although I don't have to stare at it like I do the front blades as I drive.
Its a bit involved and requires you to plug the hole once you remove the motor so you do not get rain in your trunk.
Cheap replacement, great fit, more visibility.
I'm new to the insight scene, just bought mine a week ago, averaging 68.9 mpg so far. Mileage has been increasing as temperature goes up and I learn how to feather the car, I came from a '93 del sol so I'm loving the space. Lifetime mileage when I got the car, 49, at 107,000, ouch. Anyways I've been reading and studying all the greatness this site has to offer and figured I would add my own experience with my first mod, which may help others. I realize this post is old but I too had the issue with thinking the rear view in rain was super small cleared only by a 16" blade. I believe the blade to be original as it was barely alive. Anyways i went to the local dollar store and bought a 22" blue coral brand wiper blade for $3.88, it fit perfectly and is a 100% improvement. Didn't have to modify anything and the wiper functions great. Hope to help someone out there curious about bigger blades. Thanks
I really haven't paid much attention to the rear wiper. Is it not the typical "J" hook setup that most blades use?
Regards,
Jerry
Yep..........24 inch. max.
HTH
1 - 19 of 19 Posts
