I just purchased a 2010 after daily driving a 2000 for many years. Very excited to step forward. I'm about to lower this new 2010 on Tanabe springs. While it is apart I'd like to change the rear shocks. I believe I heard some Civic rear shocks will work in place of the factory 2010+ Insight rear shocks. Is this true? Does anyone know the exact part number (KYB, Monroe, factory), or the Civic year range?
Any help would be appreciated. Thank you.
Yes
Just to confirm, I have a 2010 Insight and I just changed my rear factory shocks for the "KYB 343460 Excel-G Gas Shock" which are normally used in Civics, and they are perfect. Swap took about 20 minutes, nothing to modify, really simple.
Again, if you need rear shocks for a 2010 insight, you can use KYB 343460 Excel-G Gas Shock which run for about $90 for both on ebay.
The KYB 343460 has a compressed length of 15.48 in. and and extended length of 21.46 in. it's designed for the 06-11 Civic.
The 348016 has a compressed length of 15.51 in. and an extended length of 23.75 in. it's for the 09-13 fit.
Both use an E2(12.2×39.5) lower mount and an S1 stud upper mount, so they should both bolt on. I would go with the Civic shocks like Madmath said, it's a heavier car so they should work better with the Insight, plus they're cheaper.
