Hi guy's,
Few mounth's back, when i happely convert to the Insight, i had mix feeling about the Insight's stability on the highway.
Thanks to Guillermo, i have installed a set of Yoko ES-100 185-60-14.
That was a huge +.
I also modified the camber; -.5 in font -1.0 at rear.
Again a major + in the stability and also in steering input.
But, in tight turns, the rear end was a little twitchy for my taste, you can feel the looseness, it did'nt grab much...
This is how i change the already potent Insight into a Autocross marvel !
Guillermo that may interesse you..
I have installed a set of wheel spacer made by OMP, the spacers are originally for a VW, had the hub lip remove by a machinist, so that the surface are perfectly flat, installed 70mm wheel stud, reduced to 60mm by the machinist.
i also had to remove a bit of plastic off the wheel skirt as the tire was very close to it, i just shave the area where the tire would have rub.
Now the car as a go-kart like handling, the rear end stays put.
I am very happy with this, very happy.
P.S. sorry for bad english.
That was a huge +.
