Hello everyone. I am new to the Insight community. I hope this is going in the right place. I purchased a local 2001 Insight, and it has been a slow and bumpy process getting it back up and running again.
The previous owners told me they had the hybrid battery completely replaced in 2015 by Hybrid Revolt. These batteries lasted two years, and stopped working in 2017. The owners tried to reach out to Hybrid Revolt, several times and apparently were ignored... by this point, the owners no longer wished to deal with it, so it sat and eventually they put it up cheap, and I scooped it up in October of 2019.
I brought it to a Honda dealership and they dragged me through a series of telling me to change out both control modules on top of the battery (because they were wrong for the year of the car) as well as the DC-DC, and then scratched their heads when none of that worked and said I needed a new battery. I was not pleased with their pretending to know what was going on. The car has been stationary in my garage since. I attempted to grid charge the batteries because I read that this was a common issue with failing packs.
With no knowledge of the insides, I went ahead and hooked up a grid charger to see what i could get. The pack never charged past 110 volts. I continued to try charging and discharge cycles, and eventually I saw smoke and my fan shorted... so I walked away for a few months. I returned to the car in May, and decided to tear into the pack to see what was going on.
When I got inside, I was greeted by corrosion corrosion EVERYWHERE. Every single cell was corroded and most if not all were leaking . I removed the Hybrid Revolt sticks (their stickers were all over the inside of that pack), and swapped them out with ones i found on eBay. All tested good, and came from one provider.
I cleaned away all corrosion, and replaced a few parts that looked beyond saving. I hooked everything back up. I installed the grid charger so I could have it ready if needed, and it was a good way to see that the pack was reading out good numbers and working. The grid charger showed 160 volts. I thought everything was looking up from here.... then I went to start the car, and I was greeted by a check engine and IMA light after hearing a pop sound come from what sounded like in or near the DC-DC 5 seconds after turning the key.
I attached a google drive link, so you guys could take a look at the video of the key turn and the evidence of a healthy pack. If I need to upload more things to that link, I will. Insight
I took an OBD reading and got P1568. I also read blink codes of 67 and 70.
I think the thermistors may be the culprit... but I can't seem to find anyone selling them, so I never was able to troubleshoot, so the car sits yet again...
I am hoping one of you could point me in the right direction/tell me what you think may be occurring, and perhaps where I could find a dang thermistor harness!
Thanks in advance!
Chris
Thanks in advance!
Chris
