I am going to put a new battery in my 2000 insight. The one I have shows that if I see Blue in the window it is OK, if Red needs water and White needs charging. I see only a metal ring. No colors. However, I can not see any fluid on the side between the level marks.
So I have two questions:
1. Are there any good suggestions for a replacement batter for the little 12v?
2. Is there any special procedure to follow when changing the battery due to the loss of power to the computer?
Any help is appreciated.
Thanks in advance for your help.
Frank :?
Frank :?
