pg 179 of the manual states:
To thoroughly flush the transmission, the technician should drain and refill it with Honda ATF-Z1, then drive the vehicle a short distance. Do this three times. Then drain and refill the transmission a final time.
okee..
5.8 qt capacity x 4 refills = 23.2 qts
Am i correct in deducting from this that I will need to purchase 24 qts of ATF-Z1 to properly change out my transmission fluid? or does "do this three times" mean drive the vehicle a short distance three times on one "flush fill" of ATF?
okee..
