I apologize for the separate thread. This is abit related to https://www.insightcentral.net/threads/2012-insight-ex-stock-radio-upgrade.125422/#post-1450225. I was wondering if anyone has successfully tapped into their reverse lights (for backup camera installs) via the driver side fuse box. Crutchfield advised wiring the aftermarket stereo's reverse camera wire to it. However, I'm having trouble locating it. I did find the wiring documentation
83590
This seems to match the instructions from crutchfield:
Reverse Light ( + )dash fuse box, L.GN/WT 49 pin plug (C), pin 21GN
Parking Brake at switch, white 1 pin plug, pin 1OG
Do you guys think I have right wire? It's so difficult to see in the pic I took below:
83591
Discussion Starter #2
I did confirm I had the correct wire. Unfortunately I cut it accidentally when I was attempting to tap into it so I had to use the reverse wire from the aftermarket receiver to bridge the reverse lights wire I cut. Confirmed I still have reverse lights, and receiver triggers the camera on when put on reverse.
I had not considered tapping into the fuse box for the reverse light trigger, this is a good idea. I'm surprised I hadn't considered this.
