I think that if Honda wanted to, they could make our Insights, with minor re-engineering into a 100MPG car.
Think back to the first time you took a ride in your new 5 speed Insight.
One of the things that surprised me was how no new skills were needed to drive the car.How smooth the transition was. It also disappointed me, I wanted to turn on the electric when I wanted to, not after mashing down on the gas first.
Here I was driving a state of the art Hybrid car. It had a 1 liter super efficient gas motor, that could cruise at a constant 60 MPH with a fuel economy of 60+ mpg , with 100+ mpg possible when drafting, tailwinds and coasting all contribute to the mileage.
Use a heavy foot, and don’t pull back when your target speed is reached to feather the gas pedal, and you may drop to <50 mpg on the same route.
I immediately thought to my self where is the IMA control mode button.
We are basically unable to control the time of activation or torque contribution of the electric part of the IMA, without first causing the gas engine to try to respond to the request for more power. This causes us to sacrifice gas whenever more power is need to crest the hill, or pass a car, when in fact the same acceleration could have been produced by the electric power plant that may be fully charged and perfectly able to give us the gentle torque increase that we are asking for without changing the MPG of the gas engine at all.
What if the throttle worked in a reverse mode. In this mode, when the throttle is pressed down to ask for more power the electric assist is the first to respond, not the gas engine. Press down further on the throttle, the gas engine, which was sitting at a constant 100 MPG or other high MPG throttle position, powers up to meet the request for high power. The engine throttle control would lag the electric instead of leading it. The control program would auto feather the assist and gas to try for nearly constant lean burn.
Mostly a software change, no new controls. Maybe bigger batterys maybe not?
:wink:
:wink:
