Hi all, I just hooked up a Rostra Cruise on my CVT this Saturday. I am having trouble figuring out where to hook up the dark blue RPM wire. One post said it it was on the rpm test hookup behind the battery. I don't see this hookup anywhere. Also I read it was near the master cylinder. Still no luck. Does this test port exist on the CVT? I would think there would be an RPM wire on the computer under the passengers feet where the VSS was located. Also, I don't have a wire to hook to the neutral safety switch on my harness. Did I get the wrong harness by chance? Does anyone know where the NSS wire is? Someone said it might be pin7 on the same plug the VSS is located but they needed to confirm.
Any info would be great.
Thanks,
Matt
Thanks,
Matt
