If you have a scangauge2 here is the air fuel ratio codes for the X gauge the numbers will be negative but it will show air fuel ratio to the nearest whole number.
14 to 15 for normal ratio
22 to 25 for lean burn
30 to 38 for fuel shutoff (obviously the fuel shuttoff is the wideband o2 limit)
Here is the code
TXD 686AF10114
RXF 044105140000
RXD 2808
MTH 00670100FFC9
x2 as Natalya.
