Hi folks,
I recently started running my insight from shell v-power gas, I also changed the air filter (still stock).
Well the insight really feels more "peppy", I am not sure which made the biggest difference or just a combination of the two, I also noticed a very slight hesitation before I started using the shell, but now its gone.
I remember reading somewhere that shell v-power has a lot more detergent in it and its good for helping clean out an engine with some coking, anyone else try this, I think I will keep on using it for now.
Chris
I tried the V-power for two tanks. I went back to Chevron. The car performs much better with the Chevron Supreme. Mileage, performance (acceleration), start-ups and idle. I have tried additives and everything and Chevron Supreme is the best.
The Texaco on the corner near me converted to a circle K, then to a Shell within a couple of months. I did a little research and it turns out Shell gas is probably the best for the mere fact that Shell's gas in my area is 30ppm sulfur where most other stations are in the 200 to 300 ppm range. 30ppm is the california "clean gas" standard. So from this I'm using Shell from now on. I have not however noticed any power difference.
Just switched
I switched to V-Power and noticed a little difference in performance, but nothing grand. My mileage went up to but I think it had more to do with my driving then anything. I just got my insight 3,500 miles (a month) ago and I'm still trying to get my technique down.
