For those with squishy packs that can only do limited assist/regen without falling over a simple limiter circuit is possible.
Limit current except when starting (which is very short duration <1s) to 50 or 25% of the requested amount.
Current limit set by two pots on a tiny pcb or via software update and pcb could be installed in footwell or in ipu compartment.
Something very simple using an 8 pin 12F683 pic is possible on the CMDPWR line for the G1 Insight.
4 wires to connect. 5v power from the ECM or MCM and cut the cmdpwr line (insert device) and pic then simply reduces or boosts requested power by x amount.
Could be programmed for other current reductions or increases in fact!!
So could act as an IMA KERS current boost device for those with good batteries who want more assist/regen at lower throttle levels.
So when car is requesting 50% assist or regen you get 100% etc etc
Can be programmed for assist boost or regen boost only as required.
So for those who don't like using assist but like a full battery, you could limit assist to 50%.
This would mean the battery remains at a higher soc overall as regen levels would be normal.
Circuit is about as simple as it can get. Might keep your struggling battery going for quite a while
Any interest?
Any interest?
