Purchased 4/21. 195,000- Usual engine clicking, my 105,000 is similar..
No drips showing but oil moisture apparent on bottom- VC gasket looks old.
CVT fine- Lower mm needs changing- All brakes AOK. New Davico aftermarket upper cat installed
to engine block with heat shield brackets removed from old one welded on but
shields not attached. These cat flanges are not threaded. Reinforcing bar attached to engine only.
New spring bolt cat connector set included.
When purchased started immediately with big bat when 12V inserted.
Old 12V restored in january with epsom salt/distilled water but no guarantees on life.
No codes- brought home installed cable and prolong grid charged a few days anyway.
Auto stop always works. Smooth steering wheel surface.
EGR disassembled cleaned and scrapers turned 180' for the hey of it....
unsure of cap edge locks so added hose clamp.
Have driven about 30 miles since including 3 today to check heater [works] and AC-
fan works [but no cool].
The 1st owner of 2 before me...much adhesive-backed 1/2"+\- foam tape and duct tape applied to
apparent suspect draft and air intake areas in engine compartment/fuel pump air channel area/trunk-
particularly around and in air filter box which remains out of car as I ran out of time for cleaning it.
Solar fan panel in rear window and trunk fan removed- wires remain.
Roof sunned and antenna base rubber worn away.
Dent in hood. All window/door/mirror/wiper components smooth. Various scuffing to body.
3rd brake light [50% bulbs working]/spoiler NOW REMOVED and disassembled will need work or replacement.
Interior needs detailing- mold or similar soil spots present on door panels, headliner edge +\-.
Radio and speakers removed- original radio and speakers from my #1 included with parts.
Trunk liner cut in half bottom/top. E brake handle surround with multiple drill holes to attach
fashionista armrest now with worn top pad both included. Rear hatch lift rods left 0% right 50%.
4 Dunlop Wintermax 165/65/14 79R 3- 80% 1- worn out.
all underbody panels included. Side cover pin holes need plastic welding repair.
Missing driver, rear, and trunk rugs, oem jack...have unused heavier duty and larger 'big red' jack if you like will include.
