I know there have been lots of discussions here about the CATALYTIC CONVERTER, but still I have some questions to ask your experts here:
1. Is that true Insight doesn't even need a CATALYTIC CONVERTER to pass even the most strict CA emission test?
2. If #1 is true, then the only reason Honda put a CATALYTIC CONVERTER on Insight is because of the lean burn, which creates too much NOx that may be over the emission limit but won't be detected at the test, right?
3. Is that true only the manual transmission version of Insight has lean burn? If it's true and #2 is true, then the auto transmission Insight doesn't even need a CATALYTIC CONVERTER, right?
4. If #3 is true, then why the CATALYTIC CONVERTER for the auto transmission one is more expensive than the manual one?
(CATALYTIC CONVERTER, Insight, Manual Trans 00-01 $592.04
CATALYTIC CONVERTER, Insight, Auto Trans 01-05 $1,245.20, at Mesa)
5. How many CATALYTIC CONVERTERs are on Insight? If I have two (2) P0420 codes (both for Bank 1) and nothing else, does it mean I need both front (engine) convertor and the exhaust convertor?
6. If I only need the exhaust converter, and can buy it plus
1 donut gasket
2 flexible joint bolts
2 flexible springs
all these for $299, do you think it's a good price? We are talking about all brand new, genuine Honda parts, of course (Imgage URL as follows).
Thanks!
1 donut gasket
2 flexible springs
Thanks!
