Mine does the same thing. LB with any load is really bad. It wasn't the EGR system, TPS, plugs, coils, valve lash, compression, LAF sensor, or ECM. I'm trying cleaned injectors next.
Bucking or "herky-jerky," as it's been called here in the past. I'll be cruising at maybe 45-50 MPH at 125 MPG, come to a slight hill, give it a little gas to maintain speed, and it'll drop to about 75 MPG and start bucking. Sometimes really badly. Giving it more gas will drop it down to about 50 MPG and it'll run smooth again and begin accelerating. I can't maintain LB on level ground at highway speeds either.@Gasoline Fumes, then hopefully this exercise will help both of us. What specifically happens under load in lean burn?
Yep. I suspect that this is underdamped response to various inputs. I hope that examining air-fuel ratio, manifold air pressure, EGR position, injector pulse width, and maybe some other stuff (timing?) will tell a story. It might be nice to have a measurement of fuel rail pressure and some other stuff.Bucking or "herky-jerky," as it's been called here in the past. I'll be cruising at maybe 45-50 MPH at 125 MPG, come to a slight hill, give it a little gas to maintain speed, and it'll drop to about 75 MPG and start bucking. Sometimes really badly. Giving it more gas will drop it down to about 50 MPG and it'll run smooth again and begin accelerating. I can't maintain LB on level ground at highway speeds either.
Umm, why not just use a scan tool?This is going to take a while. I need to learn kicad and find a PCB house.
Maybe Insights do that too. Mine will fire ATDC at low RPM and high load. Makes it feel like it's a 6000 lb Insight. I've thought about connecting a knock sensor to the ECM that's isolated from the engine to see what the timing is without knock. And carefully listen to how much it knocks! I should probably clean some injectors first.hey sean i can tell you what happens when i tune my silverado too lean and put a load on it.. my knock sensor goes full tilt and pulls all the ignition advance out to save it from preignition resulting in Zero Power Mode.. obviously silverado wasn't designed to do lean burn hence why i tried it lol.
Great question! I do own an advanced scanner that can read and clear the ECM, IMA, EPS, airbag etc systems. Newer cars use CAN for OBD but the G1 does not. The data rate is 10400 bits/sec or about 1000 bytes/sec but in fact most of that is overhead and one can only get less than 10 messages per sec (IIRC). In data stream modes, if you select all possible data, the sample rate drops to one sample every three or four seconds per item.Umm, why not just use a scan tool?
It's a great idea, I'm not sure yet where this will go... Keep that thought.Could you add more to the thread title? A more descriptive title might be helpful in the future if this thread ends up with some good solutions.
I have a recording somewhere taken by connecting my knock sensor to a computer's mic input. It is just a piezo element tuned to a specific frequency with a piece of metal.I've thought about connecting a knock sensor to the ECM that's isolated from the engine to see what the timing is without knock. And carefully listen to how much it knocks!
Yes, because it is supposed to do nothing at all! I am checking connections twice so that I'm not naughty, but nice to my ECM.it'll all be worth it when you turn the key and it works
Yes. There are some threads about programming the AFR PID with a formula for a lean burn display.sean are you familiar with torque app?
