The OEM wheel will not replace the spare in regards to its function as part of the rear protection in a colision. Have fun, Rick
Perhaps I'm overlooking something and thinking about it too quick but why wouldn't the OEM wheel protect just as good or better?....The OEM wheel will not replace the spare in regards to its function as part of the rear protection in a colision.
Not as much as any shop that you might find that would do the job for you.areg said:Would i be crazy...
So? They are much narrower and have much higher pressure, that should reduce both rolling and air drag significantly more than the effect of the rubber!Dougie said:None, because the spare tires are not low rolling resistance tires.
I have a spare tire its from my 2 door Insight I dont have anymore. You want it?The spare tire on my 2000 Insight has a slow leak. I need to pump it up about every week. I have tried to get a replacement tire from two local Honda dealers and a Firestone place, with no luck. The dealer that currently has the car for a battery replacement (more on that later) said they weren't able to order one from Honda and actually called a few junk yards but weren't able to find one. Their only suggestion was that they could get us a full size spare for several hundred dollars which probably wouldn't fit under the cargo area. Firestone tried to order one, but after about a month said they wouldn't be able to get it.
Surely we can't be the only Insight owners who need to replace their spare tire! Any ideas where to get one?
