Ok so you are going to try to stick a sharpie at least 3-1/2 inches down a recess hole and get a valid mark on the sparkplug........Good luck.
Put a sparkplug socket (The type that holds the plug in place) onto the plug and mark the top of the socket closest to the center line of the head (Forward). When you eventually pull the plug out with the socket, it should be easier to determine which way the plug electrode is pointing. Where the electrode wire is welded to the plug body should end up towards the rear of the car. (Viewed like the plug is in the engine)
HTH
HTH
