1 - 20 of 54 Posts
Eli (Bumblebee) is now running down the stock of pcb's and parts etc that he holds for me in the US for my various Gizmo's OBDIIC&C, IMAC&C for G1 & HCH1, etc
Once his stock is exhausted all future orders will be dealt with directly by me in the UK.
Sadly for me ;) his battery business has grown so well he just hasn't had enough time to keep up with the orders.
But I would like to thank him for his support and help.
Just to clarify and consolidate our records as we change over.
If you have ordered and paid for a gizmo but have not yet received it, please e-mail me at my signature address below,
including the paypal ref number or confirmation e-mail.
If you dealt directly with Eli then e-mail him but also copy me in please.
I sent loads of parcels out last month and I know some are still trickling through the USPS in the run up to Christmas.
If I have said it has been posted rest assured it has. ;)
Sometimes things do go missing though, if you haven't received your item one month after I have posted it I will send it out again.
It's important people confirm they have received items when they arrive.
I've been building a stock of built OBDIIC&C gauges and am trying to ramp up the supply of 3D printed boxes,
so I can supply fully built/tested/cased units in the new year.
I would like to wish everyone a happy Christmas and look forward to more Insight tinkering and projects in the new year.
Discussion Starter #2
If I haven't heard to the contrary by 1/1/2014 then I will assume all orders have been received and no one is still waiting for anything that I have said has been sent.
What's available now.
I now have some pcbs, kits and built unit stock available. :)
All items include free postage and packing, software license and updates.
Hardware is rtb 3 year warranty.
Payment via paypal, you pay the fees.
UK pricing is $ price converted at ratio of $1 = £0.60
Various OBDIIC&C case options are available on the forum, as are the free 3d printer files.
I may have a stock of OBDIIC&C 3d printed cases in the new year, details to follow.
OBDIIC&C G1 & HCH1 OBDII Display Command and Control Device for G1 Insight & HCH1 Civic.
I have built and tested units, minus the case etc $249
I have kits inc, programmed pic, cable, plug, lcd, components etc (Everything minus the case). $149
I have a plentiful stock of plain pcb's. $49
http://www.insightcentral.net/forums/modifications-technical-issues/20488-obdiic-c-gauge-192.html#post202455
IMAC&C G1 Ima Manual Command and Control Device for G1 Insight.
I have built and tested units, inc cable, lcd, switch etc $349
I have kits inc, programmed pic, cable, lcd, components etc $199
http://www.insightcentral.net/forums/modifications-technical-issues/19501-imac-c-aka-ima-control-bcm-gauge-combo-51.html#post189629
IMAC&C HCH1 Ima Manual Command and Control Device for HCH1 Civic.
I have built and tested units, inc cable, case etc $249
I have kits inc, programmed pic, cable, components, case etc $149
http://www.insightcentral.net/forums/other-honda-hybrids-discussion/21887-imac-c-hch1-civic-55.html#post221868
IMA Boost G1 Ima Boost/Reduce/Battery Protect and Kers Device for G1 Insight.
http://www.insightcentral.net/forums/modifications-technical-issues/28194-simple-ima-boost-reduce-device-10.html#post300346
Current Hack G1 & HCH1 Ima Current Increase Board for G1 Insight and HCH1 Civic.
I have built and tested switchable +30% & +44% units, inc cable, etc $199
I have switchable +30% & +44% unit kits inc, cable, components, etc $149
I have built and tested fixed +30% units, inc cable, etc $99
I have fixed +30% unit kits inc, cable, components, etc $49
I have a plentiful stock of plain pcb's. $24
http://www.insightcentral.net/forums/modifications-technical-issues/16206-inside-g1-mdm-more-power-40.html#post155028
Fan Control HCH1 Ima Fan Control Board for HCH1 Civic.
I have built and tested units, inc cable, etc $149
I have kits inc, programmed pic, cable, components, etc $99
http://www.insightcentral.net/forums/other-honda-hybrids-discussion/24439-hch1-ipu-fan-control-5.html#post251360
Simple Cycler G1 & HCH1 Simple Grid Charger/Cycler for G1 Insight and HCH1 Civic.
http://www.insightcentral.net/forums/modifications-technical-issues/25777-simple-cycler-11.html#post267804
Voltage Tap Monitor G1 & HCH1 Battery Stick Voltage Tap Monitor for G1 Insight and HCH1 Civic.
http://www.insightcentral.net/forums/modifications-technical-issues/26314-stick-pair-voltage-display-12.html#post274652
Note the Simple Cycler and the Voltage Tap Monitor are still in the prototype stage and available for experimenters/early adopters only.
Postage Policy
I'm now using Royal Mail Air Sure for overseas delivery after a couple of parcels have gone astray in the US recently.
Sadly it is more expensive :( but has end to end tracking, signature and compensation.
I will bear some of the cost but all overseas orders will now attract a $10 supplement to help cover this.
Please add it to any payment you make to me if ordering from outside of UK.
I will send you the tracking number once any item has been posted.
To track your item use this link.
Royal Mail Track and Trace | Royal Mail Group Ltd
Peter's Projects May Special Offers.
Couple of special offers for IC members on orders placed between now and end of May. :)
1) 50% Off second pcb.
For orders placed between now and the end of May I will be offering a 50% reduction on the second pcb in any duo pcb order.
Buy one pcb or kit for any of my projects and get another bare pcb at 50% off.
e.g. If you order the $49 OBDIIC&C pcb you could have another one for $24.50 or you could have the G1 IMAC&C pcb or the IMABOOST pcb for $24.50.
The 50% off applies to the cheapest pcb ordered, so if you want the OBDIIC&C at $49 and the Current Hack pcb at $24 then the current hack pcb will only cost you $12 :)
2) Free second pcb of you choice with any OBDIIC&C built unit purchase.
If you order an OBDIIC&C built unit you can have a bare pcb of your choice foc from my projects.
All pcb's offers are subject to availability.
All orders are +$10 now for insured postage as per my prev post.
Pic Programners now in stock.
I now keep a stock of the usb pic programmers I use for all my projects.
iCP01 - USB Microchip PIC Programmer
They are vital for anyone buying one of my gizmos as it is how you update the device to the latest software/features.
My price is $20 inc p&p when ordered with a pcb.
This is basically cost price as I had to pay import duty when they arrived in UK.
Ending soon
The 50% off the second pcb offer ends at end of May for those on the fence.
No idea if when it will be repeated as moving house and loads to sort. ;)
General price increase.
At the end of June I will be implementing a general price increase to cover inflation/component/postage costs etc.
Prices for all my pic based devices and grid chargers will rise by 15% from 1st July.
Sorry about that.
UK/EU Battery prices will be held whilst stocks are available as I got my last batch at a good price.
When they are gone they are gone though, and the next lot will likely be more expensive.
Peter
Discussion Starter #9
Prices still held and last chance before I move house.
Last call for any orders people want sent before I move house next Friday.
Chances are once I'm in won't get a lot of time to send stuff out for a bit.
Loads to do on the new property.
Gizmo prices still held for time being at old levels ;)
All orders recd to date have been dispatched. :)
2000 insight mt
Peter, I hope that the move went well. I would like to purchase your IMAC&C and possibly the OBDC&C if I can afford it.
Feel free to PM or answer here.
Discussion Starter #12
50% off bare pcb's!
Now I have got organised at the new address I've had a sort out and decided to have a sale and offer 50% off all bare pcb's. ;)
Kit and built unit prices remain unchanged, in fact they are likely to go up as they take up my R&D time so I don't like doing them.
So as an example the OBDIIC&C pcb was $49, is now reduced to $24.50 :)
Ditto all the others half prev price.
Postage is $15 per order.
Paypal fee is +5% on order total inc postage.
You can order upto 10 pcb's and only pay one postage fee.
How long will the offer last?
Who knows, perhaps until I run out, have to order some more and find the cost has gone up from my supplier.
I'll also throw in the tricky to obtain OBDIIC&C plug with pcb orders recd from today.
All the others parts are readily available.
OK, the universe wants me to have IMAC&C for the Insight too. YGPP.
Yay, IMAC&C + current hack :).
And a fun time was had by all.
Got a big shipment from digikey today...
*twiddles thumbs*
Discussion Starter #19 (Edited)
Progress and reminder.
All orders are currently being dispatched the next day.
Stock levels are still OK for most items.
Just a reminder.
Any device/pcb I build/supply that uses a pic processor requires a suitable computer and a usb pic programmer if you want to
be able to program a virgin chip or upgrade a device to newer software etc.
The devices included, IMAC&C, OBDIIC&C, Ima Boost, Mini BCM Interceptor, Simple Battery Cycler, HCH1 Fan Controller etc
I release updates quite regularly so why get left behind when I or others post new software ;)
The programmer I recommend is linked below, it's a good idea to order one sooner rather than later as they take a while to arrive.
The software for it is on the linked site. iCP01 - USB Microchip PIC Programmer
Alternatively I have some in stock and they can be ordered at the same time as your pcb's :)
My price is $20 each when ordered at same time as pcb's while stocks last.
1 - 20 of 54 Posts
