This is a technical post. I'm documenting it here for posterity. Most people don't need to read this (but it's cool if you want to). This might prove useful for driving IMA system with lower pack voltages (where you can't just use a voltage divider to spoof the voltage on connector 'E'.
Today is the first time I've ever looked at how the MCM measures the pack voltage. If you're not familiar, connector 'E' on the MCM has two wires (RED & WHT) that are directly connected to the pack HVDC terminals.
The input circuitry inside the MCM divides the HVDC voltage by 50, which is the same ratio used inside the PDU to generate VPIN. My initial thought was that you could tie VPIN to the connector 'E' input (modified to accept 0:5 volts, see pictures below).
Unfortunately, you can't just wire VPIN (from the PDU) to the connector 'E' circuit, because the voltage on connector 'E' is always present (regardless of HVDC contactor state), whereas VPIN is zero before the contactor engages, and then ramps to HVDC/50 (e.g. 150 V_pack = 3 V_VPIN).
Due to the above, the modified MCM throws P1577 if you use VPIN. However, if you know the pack voltage (e.g. by measuring it with the LTC6804, or dividing it down and measuring it with a microcontroller), then you can generate a compatible low voltage (0 to 5 volt, e.g. with a DAC on the microcontroller).
Why is this useful?
For systems where you're increasing the pack voltage (e.g. 200 volts), this is a more complicated method to spoof the voltage. Peter's method of using a simple voltage divider is certainly easier, and I recommend that.
However, for systems where you're running a lower pack voltage (e.g. QTY2 Honda Fit EV LTO packs), you could use these findings to spoof a higher pack voltage with just a simple 0:5 volt DAC (and the internal MCM modification shown below).
A more in depth look at the MCM's HVDC input circuit:
IC28/29/30/31/32 are photoMOS... I wasn't able to find the part number, but that's what they are. A photoMOS is essentially an LED that controls the gate on a MOSFET. Put more simply, these ICs are ON/OFF switches.
IC29 never fires (i.e. the MCM never illuminates the internal LED, hence the IC29's switch is always OFF). Honestly I'm not sure why it's even there to begin with, as it poses a safety hazard in the event either IC31 or IC29 fails. Whatever, I've happily ignored it, and even took it off the MCM and didn't get any IMA errors. I'm 99.9% sure it does nothing.
IC30 & IC28 always turn ON at the same time, and are also always OFF at the same time. When they're on, the entire pack voltage charges the 217 nF capacitor (C90). Inrush current is limited by a 15 kOhm series resistor R237. Note that once C90 charges up, it essentially maintains the entire pack voltage across it at all times... there's a very small (0.1 volt) drop every time the ADC connects (discussed below), but essentially the entire pack voltage is always present across C90.
IC31 & IC32 are also linked together (always ON & OFF at the same time). They only turn on when IC30 & IC28 are off. Thus, either the battery is connected to C90, OR the ADC is connected to C90. In other words, these ICs serve to allow the microcontroller's ADC to sample the battery voltage without ever galvanically connecting to it. That's all these ICs do.
From here, the voltage across C90 goes through a 50:1 voltage divider (480k + 10k (R244) ), which proportionally drops the pack voltage from 0:250 to 0:5 voltage. There's then a couple current limiting resistors (R253. etc), and a zener diode pair to clamp the signal between two voltage rails.
This is not a good circuit from a safety perspective, as galvanic isolation does not exist. Hypothetically, there are several ways this circuit could fail, thus introducing high voltage into the low voltage sytem. Examples:
-If the microcontroller accidentally turned all ICs on at the same time, OR;
-If R244 opened (hence no voltage divider), OR;
-If IC29 failed short (hence no voltage divider).
This circuit certainly works, and there are several downstream components that limit the current, but from a safety standpoint I give this implementation a C-... I certainly wouldn't allow it if I were a tech lead on the project. But here we are.
If I were designing this circuit, I'd place an ADC on the isolated side, then transmit the result through opto-isolators. Thus, there's no way for the HVDC voltage to ever find its way onto the low voltage side.
So here's how I modified the MCM (internally) to allow us to spoof the connector 'E' voltage using a 0:5 volt DAC (e.g. on a microcontroller). Note that the DAC must be outputting the correct pack voltage immediately after the key is turned to ON (e.g. 3 volts if the battery is at 150 volts)... this is the reason we can't drive the modified circuit with VPIN (as explained above).
The modifications are:
-Apply DAC voltage to connector 'E' positive
-Apply ENG_GND (BRN/YEL) between IC30 & 220 Ohm resistor R211
-Short out D38/R241/D37/R238 (vertical green line). This only requires one jumper.
-Remove R244 (this slightly unbalances the ADC input, but the sample rate is so low this doesn't matter.
Overall, I don't plan on using this for anything. My original goal was to try and remove connector 'E' entirely (by sourcing the pack voltage from VPIN), but that didn't work, and now I've abandoned this rabbit hole.
Why is this useful?
