1 - 2 of 2 Posts
G
Hi all,
I have bought a passenger airbag kill switch for my Insight.
I located the connector for the air bag & to double check that I have the right one I disscinneted it & switched the ignition on. Sure enough the SRS light stayed on indicating the airbag had been disconnected.
I the reconnected the passenger airbag & switched the ignition on again to check the light would go out, it didn't.
Any ideas on why not, does the SRS system have a memory that I need to get reset?
I have e-mailed you with the instructions from the Insight ESM. It looks as though you will have to reset the DTC memory. Good luck.
1 - 2 of 2 Posts
