I am making a trip to the junk yard to find some honda rims,
steel or alloy, for my snow tires. Does anybody know other Honda
models and years that will have compatible rims (crx, del sol, civic)? Even better would be a way to measure the rims on site, is the offset measurment measured from the outboard or inboard side? Thanks
Any 13" or 14" honda rim that has a 4 bolt pattern (4x100mm bolt circle) will fit. Any civic, del sol, crx, some Integras etc...
The rim offset for 14"x5.5" Honda rims is 45 mm
But 14"x6" wide rims with 48 mm offset all fit.
learn how to measure offset here:
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
You can also add to that list the wheels from the '83-'91 Prelude, and '86-'89 Accord.
rim size
I think you can fir 7 inch wide rims in there. They will JUST clear the skirts. If you're concerned, there is a lip you can file down without noticing it from the outside.
