For grid charging- Do you charge with the IMA pack switched on or off? And 12v connected or disconnected? I’ve been trying to search and haven’t found the clearest answer
IMA switch needs to be on or else you can't charge (since the pack is disconnected in the middle). No need to disconnect the 12V battery.
Gotcha.. I plugged it in and the current is fluctuating a lot. Is there anything that could cause this? It worked perfect the first time I grid charged it, it’s fluctuating between 25 and 60
Sounds like a defective grid charger. Contact the manufacturer for troubleshooting and replacement.
Update, i’m just an impatient overthinking idiot, after leaving it plugged in and fluctuating for like 45 seconds it stabilized at 300Ma, so we’re good!
