Hello Bob,
Thanks for writing and sorry to hear of your troubles. Unfortunately we have not had any similar reports. (Other sudden drops were usually due to a dead battery cell but these are few and far between.) The best way to get feedback from other owners would be to post your question in our online forum. That will reach the broadest audience.
Best of luck,
Benjamin Young
InsightCentral.net Editor-in-Chief
http://www.insightcentral.net
-----Original Message-----
Sent: Monday, September 19, 2005 5:16 PM
To: [email protected]
Subject: sudden drop in mpg ( - 20 %) and power after scheduled maintenence (injector treatment) - - now there is an EFR vacuum leak
name: Robert D. Wilson
comments:
I have had my 2000 Honda Insight for many years now and this is the first problem that I have had to deal with (...there was an earlier problem that I couldn't feel {except for the check engine light} - -which was covered under waranty).
I just recently returned from a summer vacation trip from Roch. NY to
Boulder Colo. and back, for which I averaged 72 mpg over the full 3600
miles. That is honestly better than my typical mileage of 62 for the life of
the car. But the engine maintenence light came on early in that trip (with
no REAL problems felt - a simple scheduled maint. thing). So, after
returning home, when I finally took it in to the dealership (...which has
always been very good here), everything was fine except that I noticed right away a 'sluggish' response under acceleration. I realize that
'sluggish' is a relative term, especially concerning this car, but
trust me -it was noticeably different. The other thing I noticed was a
step-function drop in mileage (could bearly sustain high 50's) and the
engine was using the IMA far more often than before (the gauge is now
typically at the half level when it always used to sit at the nearly full
level). Basically I'm not getting much power out of the burning gas and
the 3 plugs are more than a little sooty on one side (too rich mix). I
finally took it back to the dealership after changing oil (..I was hoping
that the only problem might have been their mistake of putting 40 wt oil in
instead of the 5-20 wt. --but that didn't help and the old oil DID
pour like correct 5-20 wt oil). They did a computer diagnostic run and
they reported that the injectors were working fine (a guessed concern that I had, since they had added an injector cleaing treatment in the earlier maintanence work - - I was thinking that maybe that treatment had freed-up a 'blood clot' type material that got caught 'down stream' ).
But they DID say that the EFR sysem showed a vacuum leak. They wanted to replace that system (ca. $390) to see if that would help.
Soooo... before I give the go-ahead with this exploratory (expensive) replacement experiment. I wanted to ask you folks if
anybody else had had to deal with this problem and how they solved it ?
One thing I would love to see is the shop manual page
that shows the EFR system and any stuck diaframs that may be in the system.
THANKS, guys, for any help,
Bob W.
Best of luck,
Benjamin Young
comments:
Bob W.
