I landed at 40 psi by experimenting a bit and making sure that the entire surface of the tire made even contact with the road. After a longer ride (say ~30kms) on a clean road, typically a highway, the tires will have a pretty clear color difference where they touch the road and where they do not. I started looking into this when I discovered increased shoulder wear on the tires already after about a thousand kms with 33psi. So I really have no idea how the h3ll Honda came up with this 33psi cr4p.I indeed think the 33 might be a bit under, but 45 to me feels like it would really be over. I know some others on the forums here run it, but I’m running 40 now. It already feels like having to do an evasive maneuver in the rain might be risky, so I’m actually considering lowering it a bit and seeing the impact on my mpg. Not sure how the weather is in Poland, but I wouldn’t like 45 psi on frozen winter roads myself 😬.
I once ended up with 45psi accidentally because of a heat wave in the summer and already then on dry road the handling went bananas. Maybe during "normal" summer weather I'll try 45psi but I don't think running it in the rain or winter would be safe enough.
