Well 1st off, the starts might be a bit harder because of the 3 cylinders. You really have to rev it up to 2k rpm and slowly let off on the clutch (not too easy for a learner...I still remember those days :idea: ). Shifting, on the other hand, should be much easier since the Insight had no torque. This means you can almost completely let off on the clutch before you give it gas. It would buck like crazy if I did that in my MINI. It takes practice, as you know, and if you learn on an Insight, you should be fine with any other car (albeit with a few changes in throttle and clutch position). Maybe you can just work on clutch engaugement for a while - keep it in 1st and have the student slowly lift the clutch to the point that it just begins to catch and repeat. This will let them learn exactly when everything starts happening. Just give it time...in a little while, your student will be able to launch without even using the assist.
One thing to watch out for on the Insight is that the syncros on the gearbox don't seem to be as good as other cars. The gears will grind if you shift too fast. Make sure they shift smooth and not just throwing it into the next gear. Hope that helps.
