481 - 500 of 539 Posts
Discussion Starter #481
Attached BCM Replacer Firmware update.. 140819
1) Added Assist/Regen flags to BCMD (Screen) AR00
2) Added new config item to Menu F (Centigrade/Fahrenheit)
Note this only effects temperatures displayed on the primary BCMD & CAND screens.
All other temperature values are in C as are the config settings and internal evaluations.
3) Try reducing assist/regen using the Battery Temp C Spoof variable on Menu E and set it progressively higher and higher and see what happens. The MCM at some point might decide to cutback current..
4) The change display # key now has less screens, as the sub screens are now accessible from the main screens using key 4..
So when on BCMD or CAND screens, pressing 4 cycles through the various subscreens which now includes an new screen (individual raw temp sensor x 4 data in C)
5) The default cell capacity value is now 5000mah and the soc set to 75% of that as default.
6) Some other minor tweaks.
Note the attached pdf is not a pdf, and will need renaming to .hex
This is untested in my car but seems to run OK on the bench.
Thanks for the quick response on this Peter. Hopefully I'll have time to update the firmware this weekend and give you some more feedback.
I have 4 other rebuilt oem and one Honda Civic LiPo pack (without the Orion BMS) that I'd like to test and start using. To make this possible I'll be building the plug and play adapter pigtail once I get the AB BCM connectors just ordered. I am considering moving the EXT_Alarm A connection to an unused pin on the B connector to make this task easier by eliminating having to wire the A connector. What unused pin would you suggest I use? Or can I just ignore the EXT_Alarm connection and not loose any functionality?
Will the BCM replacer work with the older Orion BMS (superseded by Orion 2) BMS?
Discussion Starter #483
44NOW
Just ignore/lose the ext alarm.
Re Orion1 v Orion2. (I have an Orion2) so know it works with that. (You've seen the videos)
I know nothing about Orion1
You would have to supply me with an Orion1 and pay for my time to try an make it work with that.
I'm currently looking at installing my 40 cell EH4 Civic Lithium pack initially with no BMS.
I have tested the subpacks and they appear to be in good shape with 4.6AH measured of the rated 4.7AH pack. Donor Civic had 13K miles on it. After looking at the specs I plan on trying to keep the pack between 20% SOC at 3.2V and 80% SOC 4V. This should provide a usable capacity of 2.75AH (4.6 x .6).
Plan on using 39 of the 40 cells with 13 taps using the replacer bcm16 tap board.
Any balancing will have to be done manually using my Powerlab8 - 8 Cells at a time.
Will using the stock OEM Junction board like Insightbuyer did in his implementation.
The EH4 Civic pack appears to have a similar 4 thermistor configuration as the OEM NiHi pack. I'll take a closer look at this in the next days to see if they measure about the same.
Longer term I want a BMS but I'm not ready to pull the trigger on an Orion2 at this point.
Any suggestions or cautions about this setup would be appreciated.
I think your plan looks pretty good.
I agree with your plan to use the Insight junction board. I'd wire the packs halves to the Insight pack switch for safety reasons.
I'll be interested in the level of balance you achieve with the PL8. I haven't been able to find a setting of the charger which will balance the LTOs closer than about 12mV.
Discussion Starter #486
Agreed please use a different thread for the Civic Lithium and recent charger discussions.
Move the recent posts over if you wish.
Thanks
Ok Peter I've been watching this for a while.
I have a few stacks of A123 ANR26650 modules in storage that may be a good fit for as a lithium pack using the BCM replacer.
I'd make a 158.4v nominal pack
Each module is 13.3v nominal.
12 modules in series.
Pack configured in 4 modules wide by 3 modules high.
These are the modules
The cell spec sheet is linked in the page.
At the very bottom of that page I also put a link at the bottom with pics that compare the dimensions of the modules with that of a stock Insight pack.
Based on the setup it looks like the boards I'd need are:
A $300
B16 $115
C $300 (6x$50)
D $50
$765 Total
Does that seem right?
I just want to say, thank you Peter, for working on this stuff and describing your insights publicly. Although, after a year, I still feel like a new Insight owner and am busy learning about the mechanical nuances, at some point that will settle down, and I'll start looking at modernizing the electric power system. Thanks for all your work. :cool:
I will not be using an orion system for my vehicle at this time.
Edit: changed "would" to "will" and added "for my vehicle" in order to clarify that I was only talking about my car. Not projects like this in general.
Why not? Several of us have them, and the BCM Replacer will support it.
I should probably start a separate thread to go into more details so as not to clutter this thread.
Basically money and not feeling urgency for it, and likelihood I might use something else. Also, I have a bunch parts around here like A123 balance boards etc.
Ah. You meant that YOU wouldn't be using it. I was thinking that you were advising that none of us should use it. Now I get it!
Discussion Starter #494
BCM Replacer Firmware update 030919.
1) Internal tweaks and optimisations.
2) Fixed secondary temp sensors display readings screen and enabled C/F conversion for them.
3) Menus all renamed with numbers. Menu A is now Menu 0 etc..
4) Add parameter id and text to the parameter adjustment screen, so you can see what you are changing.
Rename attached pdf to hex for programming. It's not a pdf!
Not tested by me in a car, only on my bench setup.
Discussion Starter #495
Thanks for all the support and interest in the BCM Replacer project at Insight Fest.
We have a couple of new early adopters as well.
We have had some useful technical feedback, so hopefully the system will get better and better with each update.
There will be a firmware update when I get back to the UK as we have squashed a significant bug that affected the assist/regen enable/disable flags.
I'll be riding with Issac today to test some stuff en-route to the car show in case anything else crops up.
Discussion Starter #496 (Edited)
Our BCM Replacer (LTO Lithium guinea pig) Tim has just left Pickerington with his newly installed 84 cell 200V nominal 20ah pack.
That's a theoretical max 4kwh, of which about 3 kwh would be routinely usable.
That is 6 times the 0.5kwh OEM pack capacity. :)
He also has the
1) +40% inbuilt current hack.
2) OBDIIC&C with integrated IMAC&C P&P
He has a fair bit of tidying to do and will do a write up with pics later.
Fingers crossed he makes it.
We took educated guesses at the various settings for the BCM Replacer, but it is a significant step forward for the project.
He is using a 7 tap module, 14 tap setup for 14x6 cells (84) total.
82501
Discussion Starter #497
BCM Replacer Generic Firmware update. 190917.
This update is for all users.. The attached firmware file must be renamed .hex, it is not a pdf!
The user manual will be updated when we/I get time.
The configuration defaults however are for a (5 module 10 tap Nimh setup)
Adjust all the menu/configuration values to suit your setup.
If you want to preserve your previous eeprom stored config values you can....
1) Photograph the screens or note your values before you update and then adjust them all manually. :(
2) You can untick the program eeprom selection in the pickit programming software. (see picture)
This should preserve your data. :) Note please check all the entries. Don't assume anything.
If a new menu entry/item has been added (as in this release, see below) you must set that correctly!
82623
ChangeLog...
1)
Fixed enable/disable Assist/Regen toggle keypad flag controls.
Previously you could set the flags but not turn them off again. :(
2) Fixed average voltage tap calculation..
3) Fixed graph scale data type bug.
4) Added new menu entry at end of menu 5.
"4 Battery Taps In Use 1-16"
This is the actual number of voltage taps being used, so it would be 10 normally for an OEM Nimh setup.
It should be set from 1 to 16. Tim for instance has 14 active taps for his LTO system.
It is used in conjunction with menu 2 item 0 (Remember each tap module can measure two taps)
"0 Battery Tap Modules 1-8" Tim for instance has 7 tap modules. OEM Nimh would be 5..
So you could have 5 tap modules but only 9 active taps etc. (Usually it would be 10 taps)
5)
Changed default re-calibration settings to allow slightly more frequent/easier positive recalibrations, and higher soc, 75% changed to 80%. (At 80% soc the stock MCM will reduce regen and try and bring down the charge level) Recalibration time has been reduced from 120 to 90 seconds.
Isaac found on his very long journey home that the OEM Nimh battery had a tendency to overcharge probably as a result of low level charging and infrequent assist. This change should hopefully reduce that tendency.
City or frequent stop start and assist users might prefer the previous values to keep the pack charged.
6) Some minor bug fixes...
Note this has only been tested on by bench not in my car.
Discussion Starter #498
I now have just about enough info to write the code for the upgraded CAN section.
I will add support for LTO and (CRZ/CIVIC) Lithium BMS boards in addition to the Orion2 CAN support we already have.
The LTO/CRZ/CIVIC BMS boards will only allow reading of cell voltages at this stage, but that's a useful addition to our armoury.
There will be some new menu entries were you can add the type of board Orio/Lto/Crz and the CAN id's of the boards connected to the system.
The Replacer will then listen for data from those boards.
So if you had four CRZ boards id's 201, 202, 203, 204 then that's what you would add.
It would check them in the sequence above and ignore other ID's on the bus while waiting for responses.
Anyway it will be a little while before the code is ready.
I need to set up the Orion2, LTO and CRZ boards on the bench to test it all.
Peter, Thanks for accommodating the Civic/CRZ BMS tap monitoring. I'll be waiting to test when you you release this.
On another subject... Is the 4 wire fan control in the replacer ready for testing? if so I'd like to use it instead of the older G1 resistor 2 speed Fan setup. I'm looking at using 1U 4 wire Server fans for my CRZ pack cooling - they are good quality, move a lot of air, very low profile, and are inexpensive. BTW the CRZ uses a single squirrel cage 4 wire fan for pack DC-DC converter and IMA drive electronics. 1569610407429.png 1569610595411.png
82772
Discussion Starter #500
I'll need more tech info on the fans, voltage current draw etc..
