Hey guys, i have seen some scattered referenced amoung other posts, so i thought i would post how i mounted my music player to the Insight. I have an Ipod. Its a nice choice for portable player because of the plethera of third party accesories for it.
In my case, it was the belkin car adapter with dock connector that made this whole contraption possible.
What i did was construct a "doc" of sorts out of some thin plexi glass. I basically took some good measurments with a set of calipers and cut a plexi box to fit the ipod. I used a dremel with a roughter attachment to scroll out a nicely shaped front piece that holds the ipod in while allowing me to acces all the buttons and the control wheel... Then i glued a right angle braket onto the box and mounted it dead center under the head unit with a pair of small screws. I used real short screws and there is some clearence between my head unit and the plastic cover below it, so i didnt have to worry about putting screws into the radio.
The nice thing about the place i put is that i can reach all the buttons while my hand is still on the shifter!
To make this a dock, and not just a holder was a little more tricky. I marked out where the connector would have to go on the bottom of the box (This is where using plexi came in real handy, cause its clear). Then i used the dremel to cut out a rought hole. I used a set of small files to enlarge the whole so that it woudl be the proper sized to hold doc connector. It took some time to make sure i got the whole in the right spot. Finally i constructted a smaller box to hold the two tabs of the dock connector in so the ipod wouldnt lock into it when it was in the dock. This second box also helps to stablize the doc connector.
The beauty of this setup is that i can then run the wire with the power adapter into the back of the dash, where i wired up a new 12 volt outlet. Because the adapter uses the doc connector, it has an audio out built into the power plug. I connected an audio cable into the auxilury input of my head unit.
All done the system works great, and my next step is going to be to paint the doc to match the grey interior. But it looks pretty good and its a nice clean installation.
I dont have pics yet, cause i have just finished playing aroudn with it, but i should have em soon, ill post em when i get em.
