I've been trying to figure out what modifications would be required to provide the max possible FE. My thoughts are below, for comment.
The goal would be to get the car to recycle its kinetic energy as close as possible to the theoretical max, presumably 95%. (I believe electric motors can be 95% efficient. I don't know if they can do that in regen mode.) That means if the car always recaptured 95% of it's kinetic energy, MPG could go well into the hundreds (at least at non-highway speeds).
I'm ignoring for the moment wind loss issues, and also cost and technology issues. Billions are being spent on hydrogen and fuel cells, which are much less efficient and are decades away. So why not focus on something that is dramatically more efficient and available much sooner? From what I read about global warming, we don't have decades.
Problems & Solutions:
1. Engine drag
This is a huge issue: run the engine only when essential. Allow it to shut down anytime the throttle is released by adding a sprag clutch between the engine and electric motor.
2. Maximize regen
a. Change the settings so regen kicks in any time the throttle is released. (MIMA style, perhaps)
b. Make friction braking unnecessary except for emergencies. Increase the power capacity of the regen system so it can slow the car much more forcefully. This presumably would require an energy control and storage system that could accept much higher current rates than batteries can. (Maybe capacitors in parallel with batteries? Maybe add a second regen system?)
Perhaps some sort of skunk works is possible to work on this?
1. Engine drag
2. Maximize regen
