I just installed a throttle control. I purchased the throttle control at http://www.awdirect.com part number AI1 $50.99 Install kit is not needed if you take a small bolt and drill a small hole across the threads. Then use a nut to cramp onto the throttle control wire.
Its mounted right next to my right knee. It was the best place to mount as its inline with the pedal. The cable is mounted to the top of the honda gas pedal rod by drilling a small hole.
So far it works good. Not to be used in town. Best suited for the interstate.
Pictures will be added this weekend.
