1 - 2 of 2 Posts
I have had P0122 appear off and on for a year. I replaced the tps and adjusted it. I got 6% at idle and 84% at wot. It was fine for 4 months. While driving I get a 1 second loss of power, check engine light, and it continues running well. Tonight, I hit a bump, check engine light, and then ok.
Again P0122 on my scanner. I checked the freeze frame and all was normal (0 Long term trim,0 short term trim, etc)- except tps showed 0. There must have been an open in the wiring, or tps connector
It is a 2001 manual shift with 146k. The egr plate is freshly clean, valves adjusted, iridium plugs at 110k, fresh air filter, grounds replaced, 2 yr old hybrid revolt upgraded new battery.
Has anyone had an intermittent open in the tps circuit? The car was a California car from 2001 until 2018; when it moved to Rockwall Tx. I see no corrosion issues.
IIRR, the TPS should be 9-90. Sounds like a loose pin in the connector?
1 - 2 of 2 Posts
