1 - 12 of 12 Posts
I already have the same car/yr. but this one has AC. It's for sale @ $1200 but had a rattling noise when idling but when push clutch down, it goes away. I had estimates to repair and AAMCO is $1700 (w/ new clutch rec.) and Honda $1400.....is that way too high and is it worth investing $ before I buy this vehicle that I know had 2 owners to date. No accidents other but has dings and prob. needs new tires.
Suggestions?
Gary
Location?
Suggestions?
Gary
Suggestions?
Gary
Yes, it sounds like a bad input shaft bearing. Is that what the quotes are for? A throwout bearing would have the opposite symptom, noisy when pushed in and quiet when released. It should probably have the synchro mod performed. I doubt those guys would do that.
Is that a more expensive job, or same range?
Gearbox has to come out and apart, may as well do synchro and clutch etc while you are at it.
You will thank me later.
ISB = Similar price range but more $ labour and less $ parts than clutch.
Discussion Starter #10
Thanks for input. Not sure if worth putting that $ into the car but price seemed right from get-go since was $1200. Also, for an '00 Insight, 165K mis. also pretty good. Time to decide!
It is probably a lot more money as I assume they were just quoting R&R the transmission plus the cost of the clutch parts. With the ISB that all has to happen plus the transmission has to come apart parts replaced. And I don't think you want to do that without performing the synchro mods. KLR3CYL could give you an idea of cost to have a professional do it, but I don't know if there is anyone in your area that knows about the mod. I've heard of people paying 3-$400 to R&R a transmission so maybe buying one from someone like Scott and having a local replace it is the way to go. But then you still probably want to do the clutch and rear motor mount.
1 - 12 of 12 Posts
