Not long ago "Silver" ran over road glass and a tire (Potenzas) went nearly flat. David used Fix-a-Flat. Afterward, the car began to shake violently at about 60 mph. The Honda dealership removed the Fix-a-Flat (the liquid bouncing around caused the shaking) and then repaired the tire. The repair was only $14 and the tire looks and drives like new.
How do repaired tires handle higher psi? We usually keep the tires at 40-44psi but not higher. Right now they are at spec'd psi but it would be nice to pump in a little more air for the mpg help.
