So last night I was driving with the family and the TPMS light came on. It was about 10pm so i waited til this morning to check it out.
When I checked the pressure in all the tires it was in the 31-33 range in all of them. None of the tires appeared low or flattened in any way. So I ran up to the local gas station and used their air tank and only put a small blast in each tire. The light stayed on until i drove after about 5 minutes the TPMS light when off.
Has anyone had any problems with their TPMS or the light coming on prematurely. If it hadn't gone off I would be taking it in for service at the local stealership.
I checked all the tires for any type of puncture, dry rot, nails and they all are clean.
I don't have my owner manual available. I looked on the door panel and it said the tires should be at 33 psi front and back. Does anyone know at what PSI the TPMS light would come on?
You're fine if that's all it's doing. I had a similar incident maybe three weeks after I got my Insight.
I had to go someplace really early in the morning (4 a.m.) and the temp when I parked the previous night was in the upper-70's. This early in the morning it was in the upper-50s, lower-60s. TPMS came on for me and I worriedly pulled into a gas station to find the same thing as you (all tires evenly inflated around 30-33psi, no flats, etc...). I figured it was the significant drop in temperature and so I just inflated each of the tires to around 36psi to be safe. After pulling out of the gas station the warning went away and I haven't seen it since.
Any idea if you had a temperature fluctuation that night?
JP
JP
No, no temperature fluctuations in the Philadelphia area. Only thing i can think of is that the tires are so small on the Insight that slight ambient variations may cause the TPMS to trigger. I don't know, just a thought.
i agree. i know there is a tire pressure thread, but i now keep the tires at 36 all around. it has given me a 3mpg boost. and no warning yet.
