1 - 9 of 9 Posts
2012 Insight Base
I have 104K on my 2012 and 2 sensors are dead so going to replace all with new tires but I can not find any link to relearning the new sensors . I have a basic model and found no TPMS in small readout panel.
None of the insights had individual TPM readings like the fancy cars have. Most tire stores have the device to link the sensors now.
2012 Insight Base
I know but most cars have a reset to reset the desired pressure etc
I know that when installing a new tps sensor you absolutely need to set it. I’m wondering (I did mine with kpro because I have a DC5) you may be able to set it with a blue tooth connected to the ecu via a torque app or something. YouTube most likely would have it listed. Even an older civic tutorial would work. I assuming. But it definitely needs to be set.
If you have a tps light, does that hamper the running of the vehicle?
It might turn off traction control & affect ABS.
If you are replacing sensors at a tire store, they will be able to link them.
Folks who need to use snow tires and do not want to have to go to a tire store or the dealer twice a year,
can get cloned TPS sensors. That way you can do the change out yourself at home.
If one has a TPS warning light because the pressure is low, once the pressure is adjusted to a normal range,
the TPS light will go out on its own. One must actually drive around for this to happen.
The newer Hondas without individual TPS readings on the dash in the MID* have a different system that does not
have TPS sensors in the tires, but senses rational differences. Those have a TPS reset button to the left of the dash.
*MID refers to the Multi Information Display in the speedo cluster. On upscale vehicles like an Acura, that display will show what the pressure is in each tire. Those can only be reset or programmed at a dealer usually.
2012 Insight Base
My TCS traction control will not turn on/off so i assume it is inop, but ABS does work so I'm confused on that , this is my first honda car (have M/C) so I am not familiar with the systems. I know GM's, MINI's forward and backwards.
I do have dash command and use it via my iphone .
2012 Insight Base
I just find it hard to believe there is not much info here on the TPMS sensors, as most insights should be approaching 100K miles and 8-10 years old so somebody else should have had batteries in their sensors gone bad. Unless most owners go to the dealer ?
I think I made it pretty clear that when you get tires mounted with new TPM sensors they will link them to your Insight.
If you do a search, in the Troubleshooting and Problems section there are 453 results.
1 - 9 of 9 Posts
