2003 Honda Insight MT blue
Yes it sounds like the isb bearing going out. I would replace the throw out bearing too.
Thanks for the reply.
I notice that the “chattering” grinding noise in gears 1-3 is louder under acceleration and lessens when I let off the accelerator.
Is that consistent with an ISB going bad?
Mine did the same thing. It got worse and i ended up changing the clutch,throwout bearing and isb and several other internal seals. Mine eventually stranded me and the clutch stop engaging. Cheap insurance since your already in there.
I really appreciate the info.
Thanks!
