P1449 isn't exclusively about the PTC strips -- it can be either about the strips or about battery module degradation. You need to pull blink codes to figure out which one. Once you have -- I'm sure you're getting P1449 @ 78 -- Ctrl-F for the right version of that blink code after P1449 in http://gershon.ucoz.com/HONDA/HONDA_DTC.pdf.
To pull blink codes, short pin 9 of the OBD2 port to the ground bracket around the port with a paperclip, then keyON and watch the IMA light blink.
As for what's causing it -- when you test your pack to rebuild it, you discharge it and recharge it. That process brings cells in line and gets the pack happy for a while. After rebuilding my pack, I'm still getting the occasional IMA light after dumping the accelerator on the highway for >30s.
The "Anatomy of an IMA light" thread here is very helpful for describing what causes the IMA light -- long story short, the BCM detects a reversed cell and interprets that as the bottom of the pack; it then triggers a recal to find the top of the pack and then current-counts to figure out what the capacity of the pack is.
When I next pull the pack, I'm going to grid-charge and re-test the potentials I get: it will show me how the "top" of the battery capacity has changed since I cycled and reinstalled my pack, and expose which cells that have become weak.
What I honestly recommend for weeding out bad cells is to dump even more current out of the battery than you currently are. I worked with ~1900W; aim for >5kW if you can. Your goal is to recreate the scenario the BCM is watching for. That will let you weed out cells that will fall flat under high current as in the "Anatomy of an IMA light" thread. The Battery Module's ON/OFF switch is rated to break this kind of current, but definitely have the BCM and MCM disconnected when you do this.
You're thinking 1500mAh, not 1500W, maybe. The battery can and does supply about 10kW at max assist (~80A @ 130V).
