1 - 2 of 2 Posts
First:
If using a grill block you need to monitor engine temp using a digital display such as OBDIIC&C or a ScanGauge. Not doing so risks overheating the engine.
Here's how the completed upper block looks from the front now:
It has lower and upper components. Here's a shot of the lower section. The base is 8 layers of pipe wrap insulating foam. It comes 2" wide so I slit it to be 1" wide, perfect for the back flat lip of the grill where I stuck the layers down. To get more height, I put a section of split sleeve type pipe insulation over that. I'm sorry it's a bit dark; I did this part at night and this is what my phone camera gave me.
I still needed about another 3/4" of height. I used double stick foam tape to stick some pipe insulating foam to the underside of the hood lip.
Here's a shot of those sections installed. I would have simply used one long length of insulation up there. But the hood lip has drain/vent holes every six inches or so, which I would have blocked off by using one full size length. So I did it in sections leaving the holes uncovered. Also one gap is wider, so you can get your finger in to release the hood latch.
Banned
Nice Work!
This mod really helped my car MPG's when I added it last Winter for sure, and again when I reinstalled it in October this yr.
Warms up engine dfaster (much) also, and heater works lots better and sooner as well...
1 - 2 of 2 Posts
