Hi there,
Update: I have driven the car on two road trips so far, over 4000 miles. I live in the mountains and commute about 90 miles a day. I still have no issues with the IMA since reseting the computers by disconnecting the 12v battery for a while. This car is the strongest of the three I have, and the cheapest!
Short Story:
Try this: I disconnected the 12V battery, and then switched the IMA circuit breaker off and back on. After re-connecting the 12V battery the IMA battery started working correctly and the IMA and Check engine light were off. Driving through the mountains for a while proved this had fixed the problem. The Battery now charges and discharges correctly and the IMA and check engine light are still off!
Long Story:
Today I found a 2000 Insight with about 100,000 miles on it that the BMW dealer had just listed for about $5000 (I thought that was low so I rushed down to look it over). I found it had both the IMA light and check engine light on, and the Charge, Discharge, and IMA Battery level indicators were all 0 bars (they were lit fully on turning the key on so I knew it was not the gages). I took it to my Honda Dealer before purchasing to have them check it. Two hours of diagnostic time later they determined that it needed a new IMA battery, and could also need other work once the IMA battery was replaced. They quoted $3000 to $5000+ to repair. The rest of the car was in perfect shape with only ~100,000 miles, and I already have a 2001 with ~180,000 so I decided to offer a low figure of $3500 anyway thinking I could swap parts and end up better off no matter what. Turns out the circuit breaker was probably tripped for some reason. I will let you know how this holds up after a couple of weeks of driving.
Good Luck
Mark
Short Story:
Long Story:
Good Luck
Mark
