Can anyone direct me to or email to me detailed instructions for adjusting the valves. I know the clearances are posted on the underside of the hood and that they are adjusted cold. but I need to know when to adjust what valves ( I have adjusted valves on many engines, but I have always had a manual the says @ TDC adjust # 1 Intake and exaust etc.)
I have 121,000 miles on the car and I just changed the spark plugs. The valves have never been adjusted and I do not have excessive valve noise. However, knowing the valve can get tighter and I risk the possibility of burning a valve. I pu;lled the valve cover and noted that some of the valves do not have the same clearance - that is for example - on the # 2 intake valves - one had no clearance while the other had some.
Any help would be appreciated.
Thank You in Advance.
Phil - 2000 Insight 64.3 LMPG
PS I am trying to aviod buying a service manual
