1 - 7 of 7 Posts
My cars ticks like timex. I bought it 700 miles ago as a Certified Used Car. Do you think the Valve Adjustment would/could be covered under warranty?
How many miles are on it now?
Probably not. Valve adjustment is considered routine maitenance, like an oil change.
BTW. I took my car twice to the dealer and requested an valve adjustment. Both times they said they sound normal and didn't want to measure them.
I finally did it myself last week. Out of the 12 valves about 1/2 of them could have been a little bit tighter. I adjusted them and the car is slightly quiter.
not sure why it matters, being that the car is under warranty, but it has 44000 miles on it.
I think i might just crack the thing open and do it myself - how much was the Valve Cover gasket when you replaced it?
Valve Adjust HOWTO?
Hey guys;
You've got my attention on this valve adjustment thing. My own car is ticking too much for my liking.
You mentioned a torque wrench and feeler gauges. I've got ENGLISH ones, do you need metric versions of both? And what about the torque range - is it the lower or higher one?
Any thoughts or feedback on HOW you did the valve adjustment would be great. Pics would be awesome. Help out an Insight brutha....
Thanks;
JKB
Discussion Starter · #6 ·
Re: Valve Adjust HOWTO?
Usually, the feeler guages have both measurements on them, since you specifically say that you have SAE ones, I would just find out the specs and convert - like if you know your valve should be set at .5mm, then use a .020 inch feeler. (actually .019685 - ha)
I don't own the shop manual, but I bet it is a very few ft/lbs, ior possibly in/lbs. 7ft/lbs seems to be common for clamping rubber VC gaskets, but be sure to go by the book.
Well, I'm no help here, but I bet these valves are just like any other valves - thank god they don't use lifter buckets with shims (shims are evil). anybody have pictures of the head popped open? I'd like to see too. [/quote]
intake 0.18-0.22mm
exhaust 0.21-0.25mm
OR
intake .007-.009 in.
exhaust .008-.010 in.
Torque
Intake valve 14lbf-ft
Exhaust valve 10lbf-ft
Valve cover bolts should be tightened in two or three steps. In the final step, tighten all bolts, to the sequence I list below, to 8.7lbf-ft.
5__3__1__7
8__2__4__6
Pretty easy to do as this was my first time adjusting valves. I recommend buying the manual.
1 - 7 of 7 Posts
