I have a 2001 Insight CVT with 70k miles on it and I am 3rd owner. On my way to work one morning I start at the bottom of a tall hill from a dead stop pulling into 60mph traffic.
Using the seconded button on the RPM’s are around 4 to 5 thousand when I got to 60 almost at the top of the hill the gas engine bucks and stalls preceded by the check engine light? I pull over and the engine is still running so I try to go but now the engine will not go past 4 thousand RPM but I make it down the hill and to work. And on my way home the car runs fine? I had the code pulled and it was p1259 VTEC failure. Then I replaced the VTEC solenoid valve and oil pressure switch assembly and still have a problem (yes I checked the oil level). Any help please.
It’s fixed. After the original post that Monday me and my bother in law ran every test we could, except swapping with a known good ECU so off to the dealership. I took the mechanic for a test drive on the interstate showed him the problem told him what I had already done to the car. So the next day they call and said it’s fixed they had to reflash the ECU.
